Edit Area tool and Make Parallel tool
jcaffee
I'm having an issue in X10 using the Edit Area (All Floors) tool to rotate my site plan to a know reference line using the Make Parallel tool.  I select the terrain perimeter (on the line segment I wish to align with the reference line), then select Edit Area (All Floors).  I then select the Make Parallel tool, set to rotate the entire polyline, and select my reference line.  Everything rotates, but a line segment of the terrain that I did not select gets the perpendicular treatment.
I know I've done this before, but for the life of me, I can't figure out what user error is involved.
See attached. (Notes in plan)
Lot Trouble.zip
Thanks, Eric!  I ended up drawing a rectangle around the entire shebang and aligning the top edge with the terrain perimeter line I wanted to align originally.  Select rectangle on the line>Edit Area>Worked like a champ.  Not sure why this didn't work using the terrain perimeter.
