Arched Kitchen Wall Cabinet with Door
No1ZZTopfan
This is a rough attempted at creating arched wall cabinets with a door. As you can see in the pictures, they are two separate components. There is a reason which you will find out once you mess with them. I have attached each component so they can be imported into your library for study, modification, improvement, etc. You will find some things you can and cannot do that you can normally do with a regular cabinet. I tried everything I could think of and couldn't make a CA standard wall cabinet to look like mine. Any suggestions on how to make it full part of CA System would be most grateful. Thanks in advanced.
Arched Wall Cabinet Door.calibz
Arched Wall Cabinet.calibz
