boxerprod Posted January 30, 2018 Share Posted January 30, 2018 Hi everyone , I try to achieve something. I have a large window between 2 floors. I can not find a way to build the frame of the Floor because of this window. Would you have any tips to share ? Thank you (Sorry for my english, i'm french ) Link to comment Share on other sites More sharing options...
boxerprod Posted January 30, 2018 Author Share Posted January 30, 2018 Actualy , there will be a cut in the floor . I guess it's exactly what you did but with a bigger hole?. Can you detail me how you did the opening ? Link to comment Share on other sites More sharing options...
boxerprod Posted January 30, 2018 Author Share Posted January 30, 2018 Thank you Solver , Seems to solve my problem. Now i need to edit the structure to find the best technical solution. Link to comment Share on other sites More sharing options...
RL-inc Posted January 31, 2018 Share Posted January 31, 2018 There is a lot to be determined here.... What are the room layouts adjacent to the opening? What floors and ceilings. Posting a plan can help others help you. And filling out a signature will as well Link to comment Share on other sites More sharing options...
boxerprod Posted January 31, 2018 Author Share Posted January 31, 2018 Hi RL-Inc , thank you for your help. I have attached the plan for the 1st Floor and 2nd. On the 2nd floor : On the left , there will be 1 room and 1 bathroom. On the right : 1 dressing and 1 room The ceiling on the 2nd floor will have a "cathedral ceiling" , i'm not sure how to say it in english ( i have attached an example ). The finish will be made with gypsum board. Last detail , the roof will be "asymetric" . If you have any suggestions REZ DE CHAUSSÉE 1 _50.pdf PLAN ETAGE 1_50.pdf Link to comment Share on other sites More sharing options...
RL-inc Posted January 31, 2018 Share Posted January 31, 2018 It appears that you have a 2 story clear area in the front center of the home- defined by the railing on the upper floor. Select the "room" in this area and define as open below. Then set the ceiling in this "room" to match the absolute ceiling height of the 2nd floor. Then uncheck ceiling above this room to create the vault. Link to comment Share on other sites More sharing options...
boxerprod Posted January 31, 2018 Author Share Posted January 31, 2018 Thank you RL-Inc for the help I'll work on this. Great help from both of you . Link to comment Share on other sites More sharing options...
