JECORMIER Posted January 22, 2018 Share Posted January 22, 2018 Hey All- I hope you had a great holiday season. I did. I've got this lower retaining wall that is giving me some fits for some reason. I think it's where the elevation region and the retaining walls touch each other on either side of the back of the flattened patio area behind the house. Can't seem to remove the unwanted "extra" retaining wall floating above the actual retaining wall go away. Crazy stuff. Any help would be appreciated. Thank you- I've included a picture of the mystery floating wall stuff as well as the plan file in x8. GILLEY_LOT_926R_1-16.plan Link to comment Share on other sites More sharing options...
stephenbc Posted January 23, 2018 Share Posted January 23, 2018 Not sure what is going on here, but my analysis points to something related to having the adobe brick on the inside of the wall type you've defined. For example, if you remove the adobe brick on the inside, it all seems to work fine. Link to comment Share on other sites More sharing options...
JECORMIER Posted January 23, 2018 Author Share Posted January 23, 2018 Great, I'll try that. Thank you- Link to comment Share on other sites More sharing options...
