Sign in to follow this
Greenshell
Frame second floor addition over Brick Veneer First Floor
    27478
    Oilersfan20
    Oilersfan20
  • Similar Content
    • By 9atatimer
      I'm using X11 premier on a mac -- I have an exterior garage wall (with a centered garage door) and a gable end -- I'd like to split the attic wall of the gable end into 3 parts -- the central region above the garage door, and the left and right, to have a different material above the garage door.
      I have Default Settings > Roof > Auto Rebuild Roof set to Off
      I have Default Settings > Framing > Automatically Build Floor and Ceiling Framing Off on all framing types.
      I have Default Settings > Walls > General Walls > Auto Rebuild Attic Walls set to Off
      If I delete the roof and ceiling planes with Build > Roof > Delete [X] and then use the Build > Roof > Build Roof ... dialog to rebuild the roof and attic from scratch -- I leave the Auto Rebuild Roofs set to Off, to be clear -- and then edit the resulting gable roof on the attic layer, I can split it twice to produce the three separate wall sections, but once I change the exterior material on any of the sections, the three wall segments get replaced with a single wall again.  The new wall has my selected material, but that does me no good as I need the distinct secgments.
      Anyone know what setting do I need to turn off to maintain the manually edited gable end?  Or is this a mac bug?
      Or, barring that, does anyone know what approach will let me give the desired finish detail (attached a pic of a freehand elevation)?
    • By mddesign
      Hello all,
      I am available to do Residential Design on contract, doesn't have to be in Canada.  I am currently using X11, willing to work by the hour or a set rate.
      If you are looking for someone to do contract work, one time or on a constant basis, please drop me a line and see if I can help you out.
      Dan Middleton
      MD Design
      mddesign.dan@gmail.com
    • By Designer100
      i have been trying to work this rear roof out and cannot seem to close it up.
      I would appreciate anyone assisting me. this is all i like finishing up this project.
      Thanks,
      1411 Plan .zip
    • By Conserva
      So I've drawn up a deck on a second floor but the framing is showing up on the floor below. I feel like I am missing some small detail but I can't figure this one out.
    • By kylejmarsh
      Having an issue with wall framing height. Never had this before and have recently upgraded to X11, so wondering if it's operatior error or the program, etc. Anyway here goes:
      This shows exactly what happens. The wall framing does not go up to support the plate height.
      Have checked the following to no avail:
       Verified ceiling height was accurate
       Wall is marked 'baloon through ceiling above' so we're not talking about a hidden attic wall messing this up - the wall actually does go up to the rafter - just the framing does not.
      Any insights?
