pazzfam Posted December 14, 2017 Share Posted December 14, 2017 Hi I am building a project with a lot of changes and it was drawn by an architect. He is really busy and can not keep up with the changes. so i told him to send me the file. My question is when I draw in the imported file can I use walls and library objects from chief ?? and when i send back to him will it convert to dwg so he can review and print. I am hoping I do not have to draw in lines and all cad as it will take to long. . Thanks Adam Link to comment Share on other sites More sharing options...
rlackore Posted December 14, 2017 Share Posted December 14, 2017 You can use all of Chief's tools, including walls, etc. I assume you will be exporting your work to dwg as 2D data only using File>Export>Export Current View (DWG,DXF). During the export process, make sure the Other Options>Export AutoCAD Index Colors is checked. Link to comment Share on other sites More sharing options...
pazzfam Posted December 14, 2017 Author Share Posted December 14, 2017 Thank You Link to comment Share on other sites More sharing options...
