Sign in to follow this
REMDES
X9 Wall Framing
Hello,
  Can not get wall framing to build on attached plan.......the previous plan  has framing yet when I deleted and try to rebuild no go.....I've checked all layer sets and defaults no luck...
Thanks
Jerry x9
10100 work 11.16.zip
Change your wall definition.
Set it back to Fir Stud 24" OC (or 16" OC), or control spacing via the wall framing dialog.
Eric , Thank you that was it.  I do not understand how that got changed.....is there another way of change wall definition without going into the wall types panel???
    27450
    Elliot
    Elliot
