cannot create vertical moulding
Modo555
Hello,
I'm attempting to create a custom kitchen door. I've done this many times before but for some reason today I cannot create my glass door grills.
I draw out my poly lines then select them and right click convert poly line to 3D molding and select my molding and size. When I click done Chief creates the horizontal moldings correctly and the vertical moldings are pointing in the wrong direction. I have played with transform options etc.. I cannot get the molding to face the same direction. If i create horizontal moldings and rotate them to vertical they switch directions when they re-render. Then they will switch again if I rotate them back. This is extremely frustrating. Having the poly lines or molding intersect with other objects makes no different. Opening a new plan with no other plans open creates no difference. Moving to another work station isn't an option.
Anyone have any idea why this is happening and or what i can do to get my desired object?
Thank you very much for all your assistance in advance.
Which two profiles? I'm use core catalog CA-42. When you say one turned 90 degrees how are you accomplishing this? transform/rotate/90/relative?
I haven't done molding for awhile but i used to never have an issue with this. I even tried to copy and past something like this from another plan I did and I get an cannot some items were not copied message. I'm using Primer x9.
