hue34402 Posted October 27, 2017 Share Posted October 27, 2017 I have only used CAD before and have recently tried the architectural version. I am working on a basement design and need to create different walls. In CAD I know you can offset a wall to a certain dimension very easily. However, I do not see this option with this program. What do I use to "offset" walls and know exactly where I am placing them? Link to comment Share on other sites More sharing options...
hue34402 Posted October 27, 2017 Author Share Posted October 27, 2017 Thank you! Link to comment Share on other sites More sharing options...
dan_nel Posted August 25, 2020 Share Posted August 25, 2020 Use the multiple copy set the offset depending on what object you wish to offset. Or better still just set the general objects section to your choice for offset. Link to comment Share on other sites More sharing options...
BrownTiger Posted August 25, 2020 Share Posted August 25, 2020 If you are talking about offset walls in the basement... create your own interior wall type that fits your needs and mark it as furred in the properties > structure > double walls > furred. So to offset by 2": create a wall type "furred basement" from like interior, remove exterior drywall, add air layer 2" on exterior Link to comment Share on other sites More sharing options...
