jrt2nd Posted September 6, 2017 Share Posted September 6, 2017 I'm working on a plot plan and on some of the lines I have checked the box "show line length". The numbers show up huge on my plot plan and I can't seem to find a way to edit their size. I also wanted to change the number style for the plot and it won't change that either. I've search the forums and my "help section and just can't figure it out. Any Ideas? plot plan.pdf Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 6, 2017 Share Posted September 6, 2017 The text size for those line lengths and angles is controlled by the Text Style for whatever layer those lines are on. You can change this in Layer Display Options, in Active Layer Display Options, or in Object Layer Properties. The number style is controlled in Edit>Default Settings>CAD>General CAD>Displayed Line Length Format. The angle format is controlled in the General CAD Defaults as well under Display Line Angle as: 1 Link to comment Share on other sites More sharing options...
jrt2nd Posted September 6, 2017 Author Share Posted September 6, 2017 Thanks, I was able to figure it out from "chopsaw's" post, but the extra info you gave is very helpful too. Link to comment Share on other sites More sharing options...
