How to control CD line output
OkcDesigner
ok going to do some contract work for a friend and he wants better quality. (so do I, but given up in the past)
Attached plan and layout.
1 how do you control the shingles and brick hatch to be darker? (want to use layer set line weights)
2 how do you get text darker? (he wants RomanC how ever  lighter then the brick so looking at RomanT)
3 is this adobe and kip plotter issue?
Thank you in advance
RomanT.zip
I always use the "Plot Lines" option when I send my elevations.
Then you can set the line thickness of the edges and the line thickness of the patterns.  You can also change the colors of each in the layout by clicking on the elevation and in the bottom left corner click the "open" button.
Withers Elevation.pdf
