Window Rough Opening - Home Designer Pro 2018
Developer
I have created windows in my floor plan.  I set the window width to 24".  This is usually a stock width for the windows I use, but I want to make sure that Home Designer Pro 2018 is quoting the rough opening and is not setting the window size framed width to 24".  How do I check or set that when I set a window to be 24" wide it framing the rough opening to 24"?
Thanks, Solver- appreciate the reply.  I did check the framing, but not sure if the 1/2" (D) allowance is incorporated into the window size or not.  So when I set the window width to 24" W is that the rough opening, as most windows are quoted in rough opening at Home Depot.
