Sign in to follow this
Ginkgohouse
Wonky Casing
Good Afternoon
I have a plan where the casing on the windows in the Living Room (Wall O' Windows) is behaving very oddly.   Sometimes it will show up, sometimes not and sometimes it will shoot out into the front yard.
Is there a way to settle it down to render correctly.?
Thanks
Mark
x7
Casing.plan
Try mulling all of them together.
From the exterior, mull the 3 left units together so they look good, then copy that unit right and mull the 2 mulled units.
I believe the stacked windows nee some adjustment vertically, or better, use a single window if you can.
Thanks Eric !
Yes the mull tool did the trick.   It just seemed like the windows in general were behaving oddly as they were not " auto - mulling" when close to each other.
Thanks for your help!
    27470
    CAJNENT
    CAJNENT
