Tony_D96 Posted April 18, 2017 Share Posted April 18, 2017 Anyone else find that drawing decks in Chief is like pulling teeth? I seem to get the outline drawn in alright, but it's in the framing and creating accurate cross sections where I run into trouble. I can say as a carpenter that Chief has no idea how you're supposed to frame a deck, and it's difficult and time consuming to fix it manually. I've even tried editing the defaults and I still find it making up it's own mind when I generate framing. For example, it seems to randomly pick a joist direction when it auto generates, and drawing a bearing line and rebuilding just gives me loads of error messages. Anyway, just curious if anyone else feels my pain here, and I thought we could share general tips to help each other out. On a side note I think they should expand on deck drawing tools in future updates. When compared to drawing out walls, deck drawing tools are very limited! Link to comment Share on other sites More sharing options...
justmejerry Posted April 18, 2017 Share Posted April 18, 2017 If you set your joist direction instead of automatic it will generate the joist direction whichever way you want. all in the dbx for the room if you made it a deck room. Link to comment Share on other sites More sharing options...
Tony_D96 Posted April 19, 2017 Author Share Posted April 19, 2017 I wound up finding out that what's giving me issues is the fact that my deck is attached to the "second floor" as it's drawn (the house is built on a sloped lot). In order for the bearing lines tool to work properly you need to jump down a floor and then draw it. Good tip for future reference though. Link to comment Share on other sites More sharing options...
