Cove Edge Frame Inset Cabinets
MarkMc
This is the same job as the other recent stuff. We usually only see this as an accent or on furniture pieces, not all that common but I needed them so here they are..
If you need to change door and drawer style on these you will want to copy the door and alter the origin prior to placing it.
In use add the cabinets to library, in plan make default cabinet, design as usual then for odd configurations use replace from library.
There should be enough variables to allow altering the faces easy enough. Just determine ahead of time if you need to split the item (door/drawer) or split a layout (horizontal or vertical)
Note-these cabinets are configured that they would be easy enough to change to 3/8 beaded inset if you made the bead parts. If I end up needing them I'll post em but usually we see 1/4" beads which were the last ones I posted.
