chief_user_rob_m Posted April 5, 2017 Share Posted April 5, 2017 I did a search, and the only article (KB-01959) on this topic does not seem to work for crown. I am able to convert as per instructions, but when I check the "No Molding On Selected Edge" it does not do anything. I have tried refreshing the view after doing this, but nothing changes. I am hoping there is a solution for this and maybe I am just missing a setting. Robert Chief X9 on MAC Link to comment Share on other sites More sharing options...
rlackore Posted April 5, 2017 Share Posted April 5, 2017 The method as outlined in KB-01959 works for me. Maybe you could post the plan, or provide some screenshots of what you're doing. Link to comment Share on other sites More sharing options...
chief_user_rob_m Posted April 5, 2017 Author Share Posted April 5, 2017 Thanks for the quick reply Robert. I closed everything out, reopened and tried again, and it worked this time. Not sure why it wasn't working before, but it does now. Thanks for the reaffirmation that the instructions were correct. I must have done something strange, or the program stored something until I closed it. I did discover a manual method along the way, just in case anyone wants to stop a crown part way on a wall. Start with the same procedure, converting to polyline, then select and "cut" a section then move each section on it's own. Thanks Again!! Link to comment Share on other sites More sharing options...
