Roof Return material
Clemson_Causey
I know this should be a simple answer, just haven't found it yet.  How do you change the "roof return" material to be a different material than the roof it is associated with?  I would like metal roof returns with an asphalt shingle roof.  Any help?
Thanks Country- that is what I was hoping I did not have to do.  I had done that on the other roof but was trying to figure out if there was a way just to change the material on the auto roof section separate from the other roof.  Thanks for your reply!
Quote
Sorry, I wasn't at the computer when I answered earlier.  You can use the material eyedropper or material painter and put a different material on each separate roof plane of an auto-roof but it will revert if you rebuild. I'm not sure if that would be a problem with material lists but it does work for presentations.
