rfantclt
Fellow More-experienced CA users,
I have drawn as-built plans of a house for a renovation/addition project in CA v.12. I recently received the final survey from the surveyor with property lines, major and minor contours, the building footprint, and other typical survey information. I imported it from .dwg as a .plan file with layers for terrain perimeter and terrain, and converted the terrain using the convert tool to make it 3D. It shows up with terrain. Yay! Now I'm not sure of the next steps:
1. How do I bring the terrain into the building.plan?
2. How do I set it in place - using a Place Point or Point Marker at a corner of the house?
3. The survey elevations are in the 650' range so how what do I do to place the terrain relative to my house (1st floor 0.0)? This house has a walk out basement, if that matters.
4. I copied in a 2D version of the survey to use in plan view (on layer CAD, AS-BUILT SURVEY). When I send it to layout, the house floor plans are obscured and the secondary contours didn't come in - admittedly, this is a previous version of my survey attempt and I've since remapped the survey layers.
I have also attached the house plan, if that helps.
Thanks for recommendations from this group, as I've watched numerous videos and couldn't find any that addressed this process.
Rebecca
CA Premier X12
Zoutewelle FINAL SURVEY.plan
Muhs Existing.plan
