Sign in to follow this
Austins
Add floor to part of house
I am trying to add a two story addition to the back of a one story house with a full dormer across the back. The existing house in CA has a single story with a full dormer across the back of the house (see below). I'm trying to do something similar to the cape addition photo below.  I will remove the deck and add a 15' x 32' two story addition lining up with the dormer (i.e. extending from the deck corner of the house to the end of he main roof line up to the smaller room jut out.   I added the first floor per below. I highlight the addition and when I add the second floor it adds it to the entire house blowing it up per below.  I went in and deleted all the second floor walls in the main part of the house (see below 2nd floor removed) and the result was:an attic floating in mid air per below (2nd floor).  I read a thread about just adding he wall I want to the second floor but I have to have a second floor created before I add walls and I don't have a second floor.  thanks in advance for any advise you can give.
In the cape photo below the addition is coming off the ridge line of the main roof of the house whereas I'm trying to get at least one option where my addition comes off the dormer roof per below  (For the life of me I'm not sure how I created the one below.  It does have two floors in the addition as well as in the main part of the house.  I tried to reduplicate it with no success.
Whoops - in the cape photo in the first content of the stream not in the reply.
If the existing model has a dormer, then I imagine it also has a second floor already built -- or it should.
If so, you don't need to build any new floors, just add walls as needed.
Thanks for responding.  In the previous model I put the dormer in the 12 pitch roof over the first floor.   It turns out that I was on the right track but didn't keep going.  When I had asked the question I had added the second floor which bumped the dormers and everything up a floor.  When I deleted the second floor walls over the original part of the house that left my roof and dormers suspended in space 2 floor up rather than sitting on the house one floor up.  It hit me that if I kept going and deleted the roof and the dormers that were suspended in place and then manually recreated the roof and dormers of the original house on the first floor it might work.  I have a ways to go but at least I got past this hurdle as you can see below.
    28854
    RileyCrosby
    RileyCrosby
  • Similar Content
    • By No1ZZTopfan
      I would like to add the paint sample attached (med_sprinkle) and use it on the garage floor but each time I create the material it comes out as tiled. In addition, when it is solid its massive instead of regular size (see garage pic). Any suggestions/tips would be most grateful. Thanks.
      Using CA12 on Win10Pro
    • By MN_JohnH
      I wonder why my second floor loft flooring is sticking through the roof and can be seen on the outside of the building?
    • By JennRob
      I accidentally deleted the floor surface from my layout of a building. It appears that the top floor surface is missing leaving the subfloor. I don't know how to add a new floor surface to the subfloor (walls are built and floor plan is otherwise complete).
    • By lavorhaynie
      I've been an active user of Chief Architect for about 15 years now. I am currently using the X11 and have an SSA.  In all of these years using the software I have been frustrated with a couple things in the electrical area. First was the terrible placement of electrical connectors, they were never placed in a way that was visually appealing. I was always wasting time adjusting the lines after placement just to make them look nice on the plan.  Thank you Chief, in X11 the lines now, most of the time, place in a visually acceptable manner. A great time saver when doing the electrical!
      The second, frustrating issue is the lack of programming to address the floor-to-floor light switching. I have over the years visited ChiefTalk hoping someone had a good solution to address this issue. I have never liked any of the proposed solutions, namely placing the correct 3-way or 4-way switch on each floor then placing cad arcs or splines to represent the electrical connector. I felt it to be a time waster and it just did not feel right using a cad line instead of an electrical connector.
      So, in response to my frustration with floor-to-floor switching I came up with an idea and ran with it. I created two floor-to-floor connector symbols. The symbols are identical except that one is designated as being switched and the other is not switched.  Both are, in plan view, a 2" circle, defined as an electrical item, In 3D they are a 2" clear glass sphere and attach to the ceiling, being virtually invisible in a 3D rendering. When I am doing a floor-to-floor switch connection I place the switched symbol in the stair well then connect the switch to the symbol. The switch then automatically changes to a 3-way. I have a set of text labels that I then place over the switched symbol to indicate the usage of the switch, i.e. "To light above", etc. I have attached an X11 library containing the two floor-to-floor symbols, (switched and not switched), and the text labels I use.
      I hope these will save you a bit of time. Enjoy!
      LaVor
      ELEC CONNECTORS.calibz
    • By Doug_N
      OK so I have wrestled with this house for waaaaaayyy too long.  Still, the room over the room is fighting me.  I think I am getting close.
      This is an as-built design, with a new flat roof over a storage space in the garage to give the client stand up space in the storage room.
      The house is complex and I have not even begun to work on the basement which has two floors.  One of the floors contains a built-in swimming pool.  That should be fun.  There is a basement level under the garage as well.
      The storage room over the garage has a crawl space on the right side of the room when viewed from the front of the house.  I have included a couple of screenshots so that you can get an idea of where I am trying to go with this.
      There are a few other problems that I am having with walls not stopping at intersections on interior surfaces and exterior surfaces as well.
      Test building to get second story crawl space.plan
