CARMELHILL Posted January 6, 2017 Share Posted January 6, 2017 This a minor annoyance. When I'm working on the construction drawings I occasionally have to make a minor change to a window or door. Maybe add an egress check to it. Maybe add a comment that it needs to be tempered glass, etc.. Everytime I do this it erased the door/window schedule Manufacturer and Model Code number. Is there a way to prevent this? It should really only erase/reset this info if your changing the height and width of the window. The rest of these changes are options that should affect the manufacturer and model number. Maybe a lock option? Link to comment Share on other sites More sharing options...
dssharp Posted January 7, 2017 Share Posted January 7, 2017 Change schedule to text if need be. Or open window in dbx select egress. For general additional notes change schedule to text. Link to comment Share on other sites More sharing options...
