Sageguide 0 Posted December 17, 2016 I'm needing help, please. My client wants a curtain wall along back of house that tilts at about a 65-75 degree inward. How can I create this wall? It would run continuously for two stories. Any help would be greatly appreciated. Attached is a CAD profile of what I'm after. Thank you. Share this post Link to post Share on other sites
johnny 461 Posted December 17, 2016 Personally, I would model in Sketchup or other app (i use Vectorworks) and then import the wall as a symbol. You can leave an invisible wall in the Chief file to close your structure. The only other things i can think of would be to use poly solids for the mullions and then thin poly for the glass, or you may be able to make a roof plane from glass and then just use poly solids for the mullions. Share this post Link to post Share on other sites
Sageguide 0 Posted December 17, 2016 Yeah, I was afraid it might have to be done with Poly Solids. Thanks for replying. Share this post Link to post Share on other sites
johnny 461 Posted December 18, 2016 I was thinking more that I bet you could do this as a roof plane, and probably would be the best solution ...a solid glass plane with poly solids etc for the structure/mullions. Joe modeled an A-frame home in CA that had a roof which extended through to the 1st floor like this and it looked like that might be a solid idea to do this "atrium" curtain wall. 1 Share this post Link to post Share on other sites
