MarkMc Posted December 11, 2016 Share Posted December 11, 2016 I make a lot of door symbols and have posted a plan "kit" in the past. Yesterday had to make an 8 panel with wider than normal rail and was about to go through copy past yadyadayd when I realized I could have a V8. Instead just made a new panel (no frame) - took an inset wall cabinet, set separation needed, placed panel as "side panel inset". then split as needed. This is much faster if you need to change rail and stile width. File with- stuff to make your own panel, couple of panel symbol examples, few cabinet examples that could be turned into doors. If you need an outside edge profile on the new door you're making just add a 3d molding around the cabinet. 1 Link to comment Share on other sites More sharing options...
