MarkMc Posted November 18, 2016 Share Posted November 18, 2016 I do a lot of cabinets that need a flush inside return in the opening of a fridge cabinet. I was talking with Kelly on a thread in suggestions and while working on something she was looking for I thought I might use something similar to solve this issue. So after a little smacking things around I have something that is respectable. The returns are not quite flush-set in 1/64" which is all I can get (let me know if you can do better) Attached is a plan with flush returns on an inset cabinet along with the symbols used. NOTE- For overlay cabinets the symbol origins likely have to change, I haven't messed with those yet they might be easier. Also note that for shorter openings than shown it is a good create a new symbol closer just taller than the opening with the vertical stretch plane set higher than the symbol (As I've done with these which are for an 84" opening) I tried to use these same tricks to get extended sides but have not had success yet. Will work on it. Link to comment Share on other sites More sharing options...
