molbhanu9 Posted November 2, 2016 Share Posted November 2, 2016 Whats the best way to show this type of ceiling. loft stylesee attached.B. Link to comment Share on other sites More sharing options...
Evolution Posted November 2, 2016 Share Posted November 2, 2016 molbhanu9 I drew a simple plan, created a poly line from the room, did a concentric drag holding the c key, to equal distance. Used the outline to place soffits around the perimeter made them one thickness used a hypothetical ceiling height (no ceiling over room) set the soffits lower than the ceiling, then drew a thinner soffit inside this box connected to the heavier soffit, did a copy multipaste each way to create the boxes. Took about 10 minutes. I attempted to attach the plan I used, but for some reason it won't attach. I zipped the same file and it attached. Hopefully you can use the example ok. I don't know how to make videos or I would have done one for you. Probably by the time I get this posted some body else will have. molbhanu9.pdf molbhanu9 plan.zip 1 Link to comment Share on other sites More sharing options...
Evolution Posted November 2, 2016 Share Posted November 2, 2016 I kept trying and the plan file attached. You can group select the smaller thinner soffits and adjust the floor to bottom height to set them lower inside the larger soffit band etc. Experiment with it and see how you can make it work for you. molbhanu9 plan.plan Link to comment Share on other sites More sharing options...
