Christina_Girerd Posted October 12, 2016 Share Posted October 12, 2016 I have a sloped ceiling plane in a room so the "auto" crown molding doesn't work since that only seems to work for a flat ceiling. I drew CAD lines and converted them to 3D molding in elevation views which worked, but it looks bad at an "outer" corner in the room as the moldings aren't intersecting. I thought I might be able to join them in plan view like you can intersect two CAD lines, but I don't seem to be able to do that. See attached image. Suggestions? Thanks. Link to comment Share on other sites More sharing options...
MikeJG Posted October 12, 2016 Share Posted October 12, 2016 If you use one polyline to go around that corner instead of two, that won't happen. In fact, I would do all of the crown in that room as one polyline. You can use the break line tool, then turn one section 90 degrees and line it up with the wall for a quick fix. Link to comment Share on other sites More sharing options...
Solution Christina_Girerd Posted October 12, 2016 Author Solution Share Posted October 12, 2016 Thanks, that worked well. I didn't realize I could still adjust each line in elevation view to match the roof slope while they were connected as a polyline. Link to comment Share on other sites More sharing options...
