capitaldesigns Posted October 2, 2016 Share Posted October 2, 2016 I am trying to rotate my floor plan 90 degrees to the left so it will fit better on the final layout sheets. I have turned on the all on layer set then highlighted the entire floor plan with a marquee. When I do this no edit handles appear to click onto to rotate the plan. I can select individual items in the plan and the edit handles appear. But when I select the entire floor plan no edit handles. I tried using the rotate plan view at the bottom of the tolls menu, but that rotates everything in the plan file even the door and window schedules. How do I rotate the floor plans only? Thanks, Mike Link to comment Share on other sites More sharing options...
capitaldesigns Posted October 2, 2016 Author Share Posted October 2, 2016 That worked. Thanks Eric. Link to comment Share on other sites More sharing options...
