olyconstruction Posted September 22, 2016 Share Posted September 22, 2016 Hi Chiefs, I am working on this as built project, and I am having some trouble straightening out the room heights. I made a camera view called BASEMENT VIEW under 1st floor cameras so you can kind of see what is happening. You will see that there is a main room that is deeper than all the others. I need the room height to be uniform (like the picture attached) but when I go to edit the structure settings I get this error saying that the ceiling height is un-editable because the rooms above have variable heights. However when I checked the room specifications above they are all uniform, having the same floor and ceiling height. I am sure some of you CA vets will know whats going on in a second, but I am truly perplexed and disturbed. Please let me know what you think, thank you for the help! AB BYRONE AS BUILT FRAMING QUESTION.zip Link to comment Share on other sites More sharing options...
Northriver Posted September 22, 2016 Share Posted September 22, 2016 Stair landing for 2nd floor is below fist floor ceiling. Do a cross section at your stairs. 1 Link to comment Share on other sites More sharing options...
