Make a floating dormer cut through a ceiling plane
SchnieppDesign
Go to solution Solved by SchnieppDesign,
Is there a mechanism for getting a floating dormer to cut through a ceiling plane.  I am designing for scissor trusses on either side of the dormer, so I have the lower pitched ceiling inside. The floating dormer does not cut through this ceiling plane. Is there a way that is more automatic than manually working all the walls, etc.?
Any help would be appreciated.
John
