Anna_Gorres Posted July 27, 2016 Share Posted July 27, 2016 Good morning! I am using the tool Space Planning (Tools<Space Planning). When inserting into my plan, no Room Name/Room Label is showing in the block. I did not see any alterations in the Object Specification Box. Help? Anna Khavanin Home.plan Link to comment Share on other sites More sharing options...
Solution Richard_Morrison Posted July 27, 2016 Solution Share Posted July 27, 2016 Change your "Room Label" text style to "transparent." Link to comment Share on other sites More sharing options...
Anna_Gorres Posted July 27, 2016 Author Share Posted July 27, 2016 Never mind - I got it! In the Room Box Specifications, go the the Line Styles Tab>Layer>Define>Select new text style. What shows and how it shows will be dependent on your label defaults. Link to comment Share on other sites More sharing options...
Anna_Gorres Posted July 27, 2016 Author Share Posted July 27, 2016 Richards answer works as well - and is probably the better option. Thanks, Richard! Anna Link to comment Share on other sites More sharing options...
