Windows are not showing in 3-d
Roe_Cole
Go to solution Solved by Roe_Cole,
For starters, copy the windows out of the attic because that's where they are showing up in the floor plan. Then delete them from the attic and paste them into the second floor. Then do an exterior 3D view and click on the wall that the windows are on and tab through until you have selected the wall that is being auto generated by the first floor and delete it. I've had problems with this in the past as well. You're auto dormer is not recognized by the first floor exterior wall and it's generating an attic wall over the front of your dormer wall. Exploding the dormer may help too but it initially didn't not solve the problem for me.
