hughstearns Posted 22 hours ago Share Posted 22 hours ago Hi everyone, I’m designing an addition and need help simplifying the roof plan. Setup The addition has two floor heights. One matches the existing house, and the other is 32" lower. The existing roof is 3 1/2 : 12 pitch with a 36” overhang. I matched both on the addition, so I can’t change them. There is an existing second-floor window (outlined in red in Image 1) above the addition’s roof. It’s an egress window, so I can’t remove it or make it smaller. Problem With the matched pitch and overhang, the roof installation will become complicated where the roof planes of rooms with different floor heights meet each other. My current solution I could push up the ceiling height on the right part with higher floor height for 1' to increase the space between roof planes. Question Is there a simpler roof layout that keeps the window clear without changing the pitch or overhang? Link to comment Share on other sites More sharing options...
