Roof design solution
hughstearns
Hi everyone,
I’m designing an addition and need help simplifying the roof plan.
Setup
  • The addition has two floor heights. One matches the existing house, and the other is 32" lower.
  • The existing roof is 3 1/2 : 12 pitch with a 36” overhang. I matched both on the addition, so I can’t change them.
  • There is an existing second-floor window (outlined in red in Image 1) above the addition’s roof. It’s an egress window, so I can’t remove it or make it smaller.
Problem
  • With the matched pitch and overhang, the roof installation will become complicated where the roof planes of rooms with different floor heights meet each other.
My current solution
  • I could push up the ceiling height on the right part with higher floor height for 1' to increase the space between roof planes.
Question
  • Is there a simpler roof layout that keeps the window clear without changing the pitch or overhang?
