Adam_Gibson Posted 11 hours ago Share Posted 11 hours ago (edited) Edit: Nevermind. In this case I just used to ramps. Why can't I delete this post? To create a small wheelchair ramp that can be accessed from the front and the side, I've been trying to edit a 3D solid. In in this case only needs to be 2" tall, but the size is immaterial. I keep running into issues and am not sure the best way to approach it. The scenario is this: The floor of a room (and the door into it) is a couple of inches taller than the adjacent open space. The ramp needs to have a zero elevation on the front and one side. Seems simple! ADA requires 1:12 pitch, although I typically use 1:18, but those numbers are also immaterial in this case. Getting the solid to look correct in 3D is what I want. I suppose I could use roof planes and make a hip, but that is not what I want. I thought I've done it in the past, but I'm at a loss. Edited 11 hours ago by Adam_Gibson Link to comment Share on other sites More sharing options...
