jmmilner Posted 18 hours ago Share Posted 18 hours ago (edited) Was updating a simple 2D drawing of a possible kitchen renovation for a family member. Not sure why but when I opened a wall specification I clicked on the Layer tab and bang: Assertion failed! Program: ...10.0 Full Version\Chief Architect 10 Full.exe File: .\source\walldlg.cpp Line: 3309 Expression: convertHdl != NULL && viewSceneHdl 1= NULL For information ....Visual C++ .. asserts The three options, Abort, Retry, and Ignore all cause an immediate crash to the desktop. At first I assumed I'd messed up the model in some fashion but, starting from a blank plan, drawing a single wall, and selecting the Layers tab of the Wall Specification dialogue produced the same results. Even opening one of the sample plans that came with CA, in a new instance of the program, ended the same way. After all manner of fooling with Windows 11 settings, I when back to Windows 10 and then to an old Windows 7 machine and it happened on both. Before I spin up a VM or dig out an even older PC, can somebody please repeat the single wall test and tell me if I'm alone? The attached JPG shows my test case on a Windows 10 Pro machine (i7-14700K, 32GB, RTX 5070, 2TB NVMe): Edited 18 hours ago by jmmilner Link to comment Share on other sites More sharing options...
PitMan71 Posted 9 hours ago Share Posted 9 hours ago I don't have 10 or I would test for you.... I don't know for sure, but in my experience these things happen because of a graphics driver incompatibility. I would do some checking to make sure the GPU driver you are using works with the chief version you are using. Link to comment Share on other sites More sharing options...
