KacyRSC Posted February 17 Share Posted February 17 Hey folks, Chief is acting up again today. I cannot figure out why the upper pony wall in my stepped foundation is clipping through the subfloor system. This should be a very basic element of this software, so I'm not sure why Chief is struggling to figure out the intersection. Looking for advice other than "you need to manually do the subfloor" in this spot because frankly that answer is unacceptable. Plan is attached below. I marked the relevant elevation view, and the corner I'm referring to. Thank you for your help in advance! Burnham Addition.plan Link to comment Share on other sites More sharing options...
KacyRSC Posted February 17 Author Share Posted February 17 (edited) Solved: I had to set my upper pony wall to be a normal wall, not a foundation wall. Edited February 17 by KacyRSC Update Link to comment Share on other sites More sharing options...
