SilverBar Posted 12 hours ago Share Posted 12 hours ago I am new to Chief Architect, so this is a pretty basic question. I seem to have lost the temporary dimensions. When I pick on a wall, window, door, etc the temporary dimensions do not pop up so I can edit them to change an items location. Is there a setting to turn them back on? I have even started a drawing from scratch, drew a rectangle inserted a door, picked on the door, and nothing. Any tips would be greatly appreciated. Link to comment Share on other sites More sharing options...
Solution ChiefTylerL Posted 12 hours ago Solution Share Posted 12 hours ago Hello @SilverBar, The Temporary Dimensions can be toggled on/off by going to View> Temporary Dimensions. You will also find the Temporary Dimensions icon along the right side of your screen. I hope this helps! Link to comment Share on other sites More sharing options...
SilverBar Posted 12 hours ago Author Share Posted 12 hours ago Thank you. Not sure how that got turned off, I must have accidently undid the check mark on the right. Link to comment Share on other sites More sharing options...
