Steve77 Posted January 16 Share Posted January 16 (edited) Hi there, I am based in Tauranga, New Zealand and currently using X17 (though still have access to X11-X17), I've been using Chief since about 2003, Version 7 and I am a Licensed Building Practitioner (LBP) in Design. I have a good understanding of the Building Code and all the requirements to achieve building consent. I'm well versed with the software and and can assist from concept stage right through to Building Consent. https://www.draftingdesign.co.nz/ Cheers, Steve Elkington steve@draftingdesign.co.nz 021 1104011 Edited January 16 by Steve77 added email address Link to comment Share on other sites More sharing options...
walterwis Posted January 26 Share Posted January 26 On 1/17/2026 at 4:57 AM, Steve77 said: Hi there, I am based in Tauranga, New Zealand and currently using X17 (though still have access to X11-X17), I've been using Chief since about 2003, Version 7 and I am a Licensed Building Practitioner (LBP) in Design. I have a good understanding of the Building Code and all the requirements to achieve building consent. I'm well versed with the software and and can assist from concept stage right through to Building Consent. https://www.draftingdesign.co.nz/ geometry dash Cheers, Steve Elkington steve@draftingdesign.co.nz 021 1104011 In X17, keep the Ruby Console open (Tools > Ruby > Ruby Console) while you work. It acts as a real-time debugger. If you're trying to pull a specific property from a custom window, you can click the object and see its "internal name" in the console, making it much easier to write a custom script for your schedule. Link to comment Share on other sites More sharing options...
larry1234 Posted September 4 Share Posted September 4 On 1/17/2026 at 4:57 AM, Steve77 said: Hi there, I am based in Tauranga, New Zealand and currently using X17 (though still have access to X11-X17), I've been using Chief since about 2003, Version 7 and I am a Licensed Building Practitioner (LBP) in Design. I have a good understanding of the Building Code and all the requirements to achieve building consent. I'm well versed with the software and and can assist from concept stage right through to Building Consent. https://www.draftingdesign.co.nz/bad parenting Cheers, Steve Elkington steve@draftingdesign.co.nz 021 1104011 With a solid foundation in the New Zealand Building Code and the ability to manage the entire process from concept to permitting, you are in a very strong position to support professional design projects in Tauranga. Link to comment Share on other sites More sharing options...
