Architectural Designer - New Zealand based
Steve77
Hi there,
I am based in Tauranga, New Zealand and currently using X17 (though still have access to X11-X17),
I've been using Chief since about 2003, Version 7 and I am a Licensed Building Practitioner (LBP) in Design.
I have a good understanding of the Building Code and all the requirements to achieve building consent.
I'm well versed with the software and and can assist from concept stage right through to Building Consent.
https://www.draftingdesign.co.nz/
Cheers,
Steve Elkington
steve@draftingdesign.co.nz
021 1104011
Edited by Steve77
added email address
  • 2 weeks later...
On 1/17/2026 at 4:57 AM, Steve77 said:
Hi there,
https://www.draftingdesign.co.nz/ geometry dash
Cheers,
Steve Elkington
021 1104011
In X17, keep the Ruby Console open (Tools > Ruby > Ruby Console) while you work. It acts as a real-time debugger. If you're trying to pull a specific property from a custom window, you can click the object and see its "internal name" in the console, making it much easier to write a custom script for your schedule.
  • 7 months later...
Hi there,
https://www.draftingdesign.co.nz/bad parenting
Cheers,
Steve Elkington
021 1104011
With a solid foundation in the New Zealand Building Code and the ability to manage the entire process from concept to permitting, you are in a very strong position to support professional design projects in Tauranga.
