cooper0013 Posted yesterday at 04:11 AM Share Posted yesterday at 04:11 AM (edited) Good evening, I am a super novice I am trying to view the framing only in the 3D view. I cannot figure out how to remove or hide the siding, sheeting and Drywall. I also want to be able to show only the framing in the orthographic views While I have your attention, how to I add the blocking to the trusses. garage 24x24.plan garage 24x24.plan Edited yesterday at 04:18 AM by cooper0013 Link to comment Share on other sites More sharing options...
tundra_dweller Posted 18 hours ago Share Posted 18 hours ago @cooper0013 For future reference these questions should be posted in the Q&A section of the forum. Your framed walls are on the Walls, Foundation layer, change them to the Walls, Normal layer. You will probably want to uncheck them as foundation walls and then build a foundation too so that your footings & slab are on floor zero as is typical. For the blocking, you can draw that in with the Roof Blocking tool, found in Build>Framing>Roof Blocking. Link to comment Share on other sites More sharing options...
