BrettASterling Posted September 1, 2025 Share Posted September 1, 2025 I've created a house in a plan and am trying to now add elevation data. Everything I've tried creates terrain that covers the lower half of the house, so I'm asking for help. What I want to do - the house is sitting on level ground (I tried putting a region here at 0"). Then, it slopes down 3' on all sides (over a 15' distance). It then levels out again for the rest of the property. Any suggestions/help would be appreciated. I tried 'elevation lines' and 'elevation regions', using the lines to show a -36" difference from where the house is. Thanks, Brett Link to comment Share on other sites More sharing options...
Rookie65 Posted September 1, 2025 Share Posted September 1, 2025 Read the terrain menu again. The setting is for distance from subfloor. A negative prefix will move terrain above the subfloor. Eliminate the "-" and that should get you started Link to comment Share on other sites More sharing options...
