WhistlerBuilder Posted May 28, 2025 Share Posted May 28, 2025 Has anyone else had the issue that after they attempted to copy settings to x17, all their settings disappeared from x15 and will no longer display even when reset? I am totally lost here. I also cannot work without any tools and nothing brings them back. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted May 28, 2025 Share Posted May 28, 2025 Reach out to support, but I ran into something similar and they helped me delete some residual files that once deleted and the software removed, reboot and start fresh. Link to comment Share on other sites More sharing options...
chris10brink Posted May 29, 2025 Share Posted May 29, 2025 @WhistlerBuilderWe addressed some issues that were causing problems with migrating from earlier versions to X17, and these fixes should be in the next update. However, its difficult to know whether the particular issue you are experiencing has been addressed. If you haven't already, please contact our tech support team. They may be able to get your migration running when you call, or they may walk you through getting some debugging information (logs, etc.) to us so that we can address the issue. Link to comment Share on other sites More sharing options...
WhistlerBuilder Posted July 18, 2025 Author Share Posted July 18, 2025 I ended up having to call support. I had to manually delete specific files, then re-install several times. This ended up corrupting all my templates and settings for x15 as well as x17. It has cost me dozens of hours dealing with the issue and I still have not rebuilt all my shortcuts, settings, templates, etc. This was an unbelievable nightmare. Link to comment Share on other sites More sharing options...
