PitMan71 Posted May 9 Share Posted May 9 Is there a way to tell chief to use the first floor wall materials to cover the floor between levels rather than the adopting the wall material from the 2nd floor? This is not always something I would need, but it would be nice to choose between the two. I know there is a work around for this by using a pony wall on the floor above with the first floor materials at the bottom. Thanks in advance. Link to comment Share on other sites More sharing options...
