NeilofOZ Posted May 22 Author Share Posted May 22 Don't understand that time frame, been to New York several times and it was 12hours behind me, I even did searched on Google Earth to see where your are located and on top of that, used google by asking the time zones for you place and mine, and that wasa 12hours Any way, thanks heaps for all your help, managed to trick the roofing by working around the Auto Build as you indicated. See attached the final solution, i punched the air when it all got together. Link to comment Share on other sites More sharing options...
