Course of brick
BadgerEngineer
Does anyone know how to properly create a brick soldier around a building. When I choose brick course for the window trim it shows properly with vertical bricks. But when you put it on a soffit to make the soldier between floors it is horizontal lines. And rotating in the data doesn't change it. Is there a way to rotate the soffit itself?
Have you tried: open the soffit dbx go to materials (think you already changed that to brick) open plan materials, the brick you are using should be highlighted, if not go to it. COPY the material and open to edit. The angle on the first set to come up change to 90. If you want a single brick change to stack bond and adjust size.
It can be a pita but sometimes you need to rotate it into place in a 3D view.......
