mpatalsky Posted February 7, 2025 Share Posted February 7, 2025 Does anyone have a good and easy way of displaying floors above and below on working drawings? I currently create a wall that I can toggle off and on and I trace over the wall above or below to show them on working drawings. I messed around with reference displays but you can't separate walls from interior and exterior. Seems like there should be an easier way? Thanks, Mike Link to comment Share on other sites More sharing options...
kellyh Posted February 7, 2025 Share Posted February 7, 2025 Reference display is gonna be the best way to do this I think. Sounds like you'll want to put interior vs exterior walls on different layers (you can set this up in your defaults) and then create reference display layer sets for each floor. Then you can use Reference Display to reference multiple floors at the same time and assign the layer set you've made to each floor. Hope that helps! 2 Link to comment Share on other sites More sharing options...
