mthd97 Posted December 30, 2024 Share Posted December 30, 2024 Hi fellow users of Chief, I have been working with the space planning tools in CAX10. When I build the house, the program creates doors automatically to a set size of 750mm wide. This still happens after I have changed the defaults to a new size of 820mm wide with the wrench tool or the global defaults before I build. When I insert a new door into the house after it has been automatically built, the door appears with the new default size of 820mm, that I have inputted into the defaults. I have created a new template file that has all my particular defaults including my standard door width of 820mm. When I build the house with the space planning boxes once again, it still automatically builds my doors at 750mm wide ? I can’t figure out what else I need to do to get the doors to build automatically to 820mm wide. Does anybody know what I need to do to fix this problem ? Edit: It doesn’t really matter that much because you still need to edit and insert doors into the correct position anyway. Link to comment Share on other sites More sharing options...
