ozaheman Posted August 23, 2024 Share Posted August 23, 2024 Attached is the file for the B+G+11 storeyed building. I am encountering a peculiar issue: just by adding a wall, it takes 7-10 seconds to regenerate before allowing me to proceed. The performance has degraded significantly, as it keeps refreshing at each step. Is there a more efficient solution to speed up the workflow? I have already tried disabling the "rebuild floor and ceiling" option and turned off the undo feature. Even after deleting all schedules, the impact on performance has been marginal. I would appreciate any suggestions you have to improve the performance. Thanks and regards, 6488704 -BASE.rar Link to comment Share on other sites More sharing options...
KevinWaldron Posted August 25, 2024 Share Posted August 25, 2024 Pulled your plan up. Played with adding and changing walls furniture etc. and it was taking approximately 3-4 count seconds for things to move, change, or add. (My machine is a I9-13900k 5.4GHz with 128 GB ram with windows 11 Pro and TTX 4090 with 24 GB with 8 TB SSD for C drive and a 14 TB SSD D drive) Personally suspect your asking CA to do more than it was designed to do. You may need a more robust Cad program or a more robust computer. kw Link to comment Share on other sites More sharing options...
