Arcadian Posted May 21, 2024 Share Posted May 21, 2024 Hi All, Getting my head around X16 and trying to adjust wall framing to include wall bridging (horizontal wall nogging here in NZ) with spacing between rows at 800mm. Additionally, we generally us a 2nd top plate 140x35 to attach ceiling lining edge to. I know I can manually adjust individual wall frames but time consuming. Anyone in Aus / NZ managed to sort this out? Link to comment Share on other sites More sharing options...
Billda Posted September 18, 2024 Share Posted September 18, 2024 Yes I’ve queried that before with CA. You can’t change the Bridging (nogging or Dwangs in NZ) Default from 38mm to 45mm and add multiple rows And I believe there’s no way to change the size of the double top plate from 2/90mmx45mm to one 90mm x45mm and one 135mm x35mm. it got to be done manually Link to comment Share on other sites More sharing options...
