jorgearaya Posted May 19, 2024 Share Posted May 19, 2024 On version 25 Premier, when using the material painter and having the Perspective Framing Overview, or the Full Overview cameras after selecting a material and applying it to the framing either the framing size changed, or the framing z axis changed. Using the material eyedropper picking up a material or color from the same view and applying it to the framing we had the same results of either framing size changing or its axis or elevation changing. We also tried selecting multiple framing members and changed the material to "bone" and the elevation of the framing in relation to the top plates changed slightly upward enough to raise the rafters from their seat cut. Yes, I will be submitting to TS for CA to check, but curious to learn whether this is a bug in 25 and likely rolled over to 26. Thank you, Link to comment Share on other sites More sharing options...
