DHerb2014 Posted February 14 Share Posted February 14 Hope I'm making sense with subject matter. I've been looking without success, for a button to activate the Active Layer Display Options that highlights the "current layer" that I'm drawing on. E.g., drawing a floor plan and adding text for a note inside a room. Once the note is finished and OK is selected, it's added to the floor plan. Easy peasy. When going back to highlight the "note" nothing in the Active Layer Display Options dialog box indicates the "live" layer that was selected. Is there a setting that I need to select that enables the Active Layer Display Options that shows what the name of the selected layer is? Attaching a simple highlight of label in "Laundry". In the Active Layer Display Options dbx, nothing is highlighted or shows what this layer is? Link to comment Share on other sites More sharing options...
DHerb2014 Posted February 14 Author Share Posted February 14 Eric, Many, many thanks for this! All of the buttons in the "gear" were checked by default. I used your selections and my life is much better. Link to comment Share on other sites More sharing options...
DHerb2014 Posted February 14 Author Share Posted February 14 I still have issues with the label showing up after changing options in "gear" that Eric mentions above. Please see screen shots of labels showing up in sliding door and garage door, even after selecting "Suppress Label" in the dialog boxes. Also, no mention of Labels in the Active Layer Set. This is the Electrical Layer Set by the way. Link to comment Share on other sites More sharing options...
DHerb2014 Posted February 14 Author Share Posted February 14 Where do I find "Schedule Specification"? I've looked for it and can't locate. Link to comment Share on other sites More sharing options...
DHerb2014 Posted February 14 Author Share Posted February 14 Thank you, but where is the Schedule located? Is it in the top task bar...where? Link to comment Share on other sites More sharing options...
DHerb2014 Posted February 14 Author Share Posted February 14 Ok, found out what the correct setting should be. 1. Schedule Specification is located in either Door or Window schedules - See attached "1" 2. Existing door (left) and two new doors (D03, D02) to right side - labels shown only for new doors? - See attached "2" 3. Existing door shown without label. See settings "3" 4. New door D03 shown with label and what the incorrect dialog box shows "4" 5. SOLUTION - New door D03 with correct settings that remove the label - "Label Layer / Use System Layer (Doors, Labels) - attachment "5" Next time, I'll try to do a video, and hope this helps anyone else with this question on "Removing Door and Window Labels on Electrical Plans" Link to comment Share on other sites More sharing options...
DHerb2014 Posted February 14 Author Share Posted February 14 Right, for some reason, mine was reconfigured and didn't display correctly. Many thanks again for your help! Link to comment Share on other sites More sharing options...
